1 - 4 of 4 Posts
Hi, I have a 2006 Ctsv1, the problem is that the battery is not charging .... I already changed the alternator and the battery, I still have the same problem ... any idea what else could be the problem?
and the TC and ABS light is also on, which I have no idea why?
all this happened since I repaired the engine a few months ago: /
Did you use an OEM alternator or some Chinesium brand? OEM is the way to go. I would bench test the alt and the battery even though they are new. Any codes?
I'd also check that all the grounds are clean and tight.
Check the wire from the back of the alternator to the starter and make sure it has continuity. If I remember correctly, there is a fusible link that could be blown so if you ohm it from the alternator to the starter, you'll know if it's good or bad.
1 - 4 of 4 Posts
