Could be a lot of things, to include 'normal' operation. Is it manual or auto? If manual, the transmission does have a normal bit of what's defined as 'gear rattle.' The input shaft gear reverberates through the clutch plates, depending on what clutch you have installed, different levels of sound and feel occur.
I'd suggest if you just bought the car, you or some other experienced mechanic should perform a very in depth inspection, to include borescope cylinders and valves, compression test, etc... Also, if it's been tuned, re-verify the tune for any lean areas. Really, just thoroughly go thru everything. For sure replace ALL fluids, to include the rear diff. When draining the fluids, filter them through white paper towels to observe any signs of metal.
Start keeping a journal, if you're like EVERYONE on this sight, you're now on a path to never ending maintenance/repair/modifications! If your married, start training early. Your wife needs to understand and embrace car parts as a good thing.
