Proceed to perform an engine leak down test.
Look carefully at each spark plug as you remove them,
In preparation to perform the leak down test.
Proceed to perform an engine leak down test.I have a 2011 v turned down it makes 600 to the wheels but it sat for a while. Being nice today I got on it pretty good and it started smoking out of the valve cover breather and the catch can. No check engine light, still idles and drives, just a butt load of smoke. The more I throttled it the more smoke it made. It was suggested that it might be a PCV valve but I’m just not 100% sure.
ok will doProceed to perform an engine leak down test.
If you really desire help, enter your entire build into your signature line.i really hope not, there is only 20k on this short block. Less than 1k with its current set up. It does have used trick flow heads on it.
LOL..Have a Bore scope? That might help you see the busted ring lands when you pull spark plugs. :😀
