21 - 25 of 25 Posts
Discussion Starter · #21 ·
Anyone know for certain what size is best for front runners then? I'm hearing mixed things. Seems like 26x6 would be safer?
You folks run tpms in your drag packs? I’m thinking no point since rears will always be deflated anyway.
I have TPMS in the drag radials because I change tires at home and drive to and from the track with drag radials on. Lower pressure at the track only.
I know for sure 26” fits without issue. The only advantage for 28’s at the track, is a little more rollout for a slightly better 60’, et, etc. but we’re talking hundredths of a second better. Basically it takes longer for the 28” front tire to clear the starting line beams. IMO, 26’s look better with skinnies also.
Discussion Starter · #25 ·
Thanks for your input. I ordered the 28s and have them now then realized I was recommended to get the 26s. Trying to see if I can return them if that's the way to go?
21 - 25 of 25 Posts
