1 - 10 of 10 Posts
· 9 Second Club
How do you reset the "SERVICE VEHICLE SOON" in the center display? I looked in the manual and it is either not in there or I looked in the wrong spot. I had my oil life % getting low and changed the oil and reset that to 100% but then I also had a service vehicle soon come up about the same time which is showing every time you start the car but I am not sure how to reset that.
· 9 Second Club
That resets the oil life, which like I said above I did. Oil life was down at like 17% or something around there and was reset to 100% but that other "service vehicle soon" always displays on start up and then I hit the arrow up or down to change the screen to show my miles until empty or whatever getting that service vehicle off the screen.
It means there is a "non-emissions system" fault detected. Most likely on the body side of the vehicle. No reset procedure unless you fix the problem or do a battery reset. If its a hard fault it will come back on.
I am currently having the same issue with my car right after an oil change. Mine is a 2005 ctsv. If you still remember where you’re arIf you still remember how were you able to solve this issue if at all.
thanks in advance
1 - 10 of 10 Posts
