None. Just "Service Power Steering " on the DICWhat codes were you getting?
"Service Power Steering"What codes were you getting
When I was diagnosing my engine's "Chirp" noise I thought the alternator was going out so I monitored for several hundred miles the voltage on the DIC.The battery voltage should not jump around. It should remain fairly stable in the high 13 to low 14V range, even at idle (the occasional "transient" is OK, there are many electrical loads that turn on and off that will effect Voltage, but the charging system compensates quickly if it's working correctly). If you're in cruise on the highway and it's moving between 12 and 14, there is almost certainly a problem. Though I can't say that'd cause the problem you're seeing. There are lots of different ways to have an electrical problem that look like wobbly voltage on a meter...
did the alternator fix it, could it be my battery possibly ?I'm getting the same message: "Service Power Steering."
After searching I found this thread.
It happens randomly, and kicks off my Competitive Stabilitrak. I've checked my voltage in the DIC when it happens and its read in the 12's, 13's, and 14's.
To that, is there a way of knowing if the alternator is kicking the bucket? Is it a progressive charge that reduces its capacity based on battery voltage, to prevent overcharging? Or is the wide range of charging voltage normal? When I'm on the highway it's never a solid number. It could be 12-14.4. Just seems odd.
I'll try the grounding bolt and replace the alternator. I'll be damned if the alternator fixes it.
Got the message "service power steering" and "active battery saver" with that weird noise driving. Battery was at 11.9v at idle. Replaced alternator as mention. Fixed the issue, noise went away and idles at 14.5v.If you receive the "Service Power Steering" warning in the DIC, it may be your alternator that's the problem. Scroll in the DIC for volts and if it reads below 14v, the alternator is likely the culprit. I had this Service Power Steering message with a little groaning from the pump and firmer steering last weekend and I was ready to replace the power steering pump. I searched for this issue and found a few threads here that said to check the voltage first because it could be the alternator. Sure enough, I was 13.X at speed with it dropping to 12v at idle. I knew 12v wasn't right so I monitored it for a few days and voltage was reading from 11.6 to 13.5v. I ended up replacing the alternator and now the message is gone, the steering it back to normal and voltage is above 14v at idle.
From one of the other threads, if voltage falls below a certain point, the computer cuts voltage to the steering system to save on power. The cut in power triggers the "Service Power Steering" message instead of "Check your effing alternator!"
I had to dig through various posts to get this info. I'm making it it's own post so others can find it easier.
Hi Mate!I figured out the problem. It was the ground underneath my AirRaid. If you get anything like this garbage on your dash it may be this ground or perhaps an engine ground. I took apart my AirRaid and lo and behold the bolt wasn't even there. I put a new bolt in with Locktite and dialectric grease and voila! Problem fixed. Nothing turning up on the dash and I can haze the tires at will. Very happy! Hope this helps someone.
Thanx for your post. You saved my 500bucks for a new alternator.I figured out the problem. It was the ground underneath my AirRaid. If you get anything like this garbage on your dash it may be this ground or perhaps an engine ground. I took apart my AirRaid and lo and behold the bolt wasn't even there. I put a new bolt in with Locktite and dialectric grease and voila! Problem fixed. Nothing turning up on the dash and I can haze the tires at will. Very happy! Hope this helps someone.
I was prepared to call BS on this advice. If you get a power steering error on dash and the steering is heavy, how is it not power steering? To make sure I was doing things correctly, I even spent a couple hundred bucks over the local auto parts store to get a genuine GM alternator. I changed the alternator and have driven the car for some miles, NO error message. Got Bearings got this right - absolutely. I've always felt computerization of cars was annoying with all those sensors, but it was an effective diagnostic tool. Now I am really thankful for forum help as the error messages may be misleading - to say the least. Thank you all, especially Got Bearings?.If you receive the "Service Power Steering" warning in the DIC, it may be your alternator that's the problem. Scroll in the DIC for volts and if it reads below 14v, the alternator is likely the culprit. I had this Service Power Steering message with a little groaning from the pump and firmer steering last weekend and I was ready to replace the power steering pump. I searched for this issue and found a few threads here that said to check the voltage first because it could be the alternator. Sure enough, I was 13.X at speed with it dropping to 12v at idle. I knew 12v wasn't right so I monitored it for a few days and voltage was reading from 11.6 to 13.5v. I ended up replacing the alternator and now the message is gone, the steering it back to normal and voltage is above 14v at idle.
Factory GM alternatorDid they install a factory alternator or aftermarket?
