It is your bumper reinforcement bar. Just spray with some black krylon, scuff it up first.
The impact bar on my 2012 was definitely painted from factory. (photo above)I don’t think it was painted from the factory, they rusted within 1 year
for normal cars left outside they started to rust within the first year, if you bought your car used someone probably painted it which is a normal thing to do if you change out the grills, headlights, add a larger heat exchanger or just wanted it to look better.The impact bar on my 2012 was definitely painted from factory. (photo above)
I just happen to have my car disassembled at the moment and I can assure you the impact "bar" wears the original factory applied black paint coating. It's likely as durable (or not) as the paint coating on all the rest of the chassis components. I purchased my car "used" with 19,000 miles.for normal cars left outside they started to rust within the first year, if you bought your car used someone probably painted it which is a normal thing to do if you change out the grills, headlights, add a larger heat exchanger or just wanted it to look better.
shit even my GMC had the same crap- practically bare steel behind the grill that I had to paint with some satin finish black.
AND there's your answer... Eastern Canada has been using liquid deicers on their roadways for decades, while Western Canada is just catching up the last few years. It's absolutely horrible on a winter driven vehicle! Depending on what geographical area of the country it initially resided, and how many winters it was driven, a less than optimally prepped and painted surface could have corroded quick. I don't feel the part left the factory unpainted, was it WELL prepped before paint? probably not. That's my guess.You would think I would have better things to consume my thoughts but these are the types of things that keep me up at night, lol. After a bit of thinking and looking at the pictures I posted, the rust is uniform across the entire bar, there are no signs of any bubbling paint or flaking, this is all surface rust that you would get on bare metal. This was originally a Canada sold car, perhaps there were years/models that the bumper bar wasn't painted coated? Maybe an oversight by GM? 2011 V Coupe A6.
Thanks again guys, great responses that make good sense! I probably over-complicated a relatively common problem with a simple solution. That's why I love this forum and all the experience everyone contributes.AND there's your answer... Eastern Canada has been using liquid deicers on their roadways for decades, while Western Canada is just catching up the last few years. It's absolutely horrible on a winter driven vehicle! Depending on what geographical area of the country it initially resided, and how many winters it was driven, a less than optimally prepped and painted surface could have corroded quick. I don't feel the part left the factory unpainted, was it WELL prepped before paint? probably not. That's my guess.
