1 - 8 of 8 Posts
Is there an easy way to access the wires that are in that grommet? I can't find a way to get in it other than mutilating the grommet. Any tips?
It's a two piece designed. Where the wires go through is a kind of hatch and can be pried out then you will have access to the real grommet.
Reactions: Overclock This
Is this the place to pry out?
I "borrowed" this pic from a wideband install thread.
Discussion Starter #4
That was it. What a bitch to remove!
Yep. Getting it back in is fun also.
Discussion Starter #6
Discussion Starter #8
I find using a bit of lubricant can help with getting the gromet back into place. Putting it back in is much worse than taking it out.
Good call. A lot of things are easier with a little lube :D
1 - 8 of 8 Posts
