1 - 8 of 8 Posts
I thought I had found a company that would make me SS brakelines for my 2nd gen, but it turns out they don't have all of the information necessary to make them. Because parts in germany require specific gov't registration and approval for them to be on your car, I can't just buy goodridge lines. Spiegler is local to me, and will make them for me with the right registration, but I need to provide them some good pictures and measurements. And rather than try to pull off a set from my car, I was hoping someone might have a spare set that they can take accurate measurements (preferably in metric) with some good pictures.
I think they have the connection information, but just need overall lengths, where a mount would be etc. If anyone could help me out, I'd really appreciate it.
Discussion Starter · #2 ·
Please!?! I really think I just need lengths and pictures, so if you have some OEM lines that you've recently removed, or SS lines not yet put on, I would be extremely thankful if you could snap a few pictures and measure (however) end to end of each line.
2009 Sedan
I don't have anything here to measure, BUT, if you look on RockAuto, they have measurements for a LOT of the parts.
152074
152075
Discussion Starter · #6 ·
Thanks, I had actually looked on rockauto and hadn't found that data... I appreciate it. I'll update with the data so that anyone else looking has access.
Here are the four links:
More Information for GM GENUINE 1761652
More Information for GM GENUINE 1761653
More Information for GM GENUINE 1761651
More Information for GM GENUINE 1761655
And data is as follows:
FL GM GENUINE 1761651
Axis 1 Length (IN)20.91
Axis 1 Length (MM)531.11
Bracket MaterialSteel
ColorBlack
End 1 Fitting MaterialSteel
End 1 Fitting TypeBanjo
End 1 Thread Diameter (IN)0.39
End 1 Thread Diameter (MM)10.00
End 2 Fitting MaterialSteel
End 2 Fitting TypeFemale M10 x 1.0
Gasket or Seal IncludedYes
FR GM GENUINE 1761652
ColorBlack
RL GM GENUINE 1761653
Axis 1 Length (IN)13.50
Axis 1 Length (MM)342.90
ColorBlack
RR GM GENUINE 1761655
Axis 1 Length (IN)12.50
Axis 1 Length (MM)317.50
ColorBlack
2009 Sedan
I hope that helps a little? I don't know if the length is TOTAL overall length measure with the fittings, or if it's length of exposed rubber hose?
1 - 8 of 8 Posts
