21 - 40 of 43 Posts
I've been searching for this solution after being told by multiple tuners I can't run even a 2.55 pulley on corn with stock pumps. Not willing to install a trap door or drill the tank. Also have emissions here so don't want to mess with the FPCM light from aftermarket pumps.
This is a perfect solution except for the labor to drop the tank. Got all winter to deal with that though. Thanks!
You can run E85 with a 2.55 pulley on stock pumps, but you do need bigger injectors.
IDX1050s are ready to install too but no tuner within driving distance wants to tune that setup. I figure it is the cooler weather up here. I'd rather be safe than sorry.
IDX1000s are ready to install too but no tuner within driving distance wants to tune that setup. I figure it is the cooler weather up here. I'd rather be safe than sorry.
Check out PatG. He has treated me well and my build is a bit more aggressive.
On my older v I ran, and it still runs a 2.55 on e85 on stock pumps And id850s.
I just happened to stumble on his install youtube video and I am glad I did. It seems like the best way to go if you plan to run an external pump.
I am currently running two of the Deatschwerks DW300c and plan on adding in the dsx kit once I hit the limits of them.
Hopefully with the ALM hat it will also allow those pumps to flow a bit better.
So what are your power levels now and planned for the future.? I have the ALM stage 1 hat (no aux pump) with DW300c pumps (and ID1050x injectors) and went 780 to the tire on 35% corn, my tuner was a little concerned with fuel pressure at the very top end of the RPM 6300 to 6800, so I added a boost-a-pump for safety. Getting the stage 2 is the best idea if you plan to go more than 800, and it keeps from drilling the tank.!
Good Luck.
Discussion Starter · #28 ·
Good Luck.
I received my stage 2 fuel hat kit and dsx fuel pump. the install was easy and everything looks amazing. My tune is Monday so we will see what kind of numbers I can put down.
you going to run stock pumps and the DSX aux pump?
Discussion Starter · #30 ·
I am running to run 2 DW300c and the DSX kit. At this point its overkill for my power level but I plan on changing that soon. If the DW300cs are enough for my current setup I will just pull the fuse from the DSX kit until its needed later.
I just wanted to clarify after stumbling back into this thread via a search, as I am going over my fuel system - I got rid of the CEL light by removing the DTC code from the FPCM itself.
Basically, using HP Tuners:
Read the OEM FPCM just like you would read a stock ECM file.
Open up HP Tuners, and under "fuel" you will see the Control Module tab.
Disable the appropriate DTC code
re-write the FPCM bin file and problem solved.
Disabling the same code on the ECM does nothing (which is what I tried to do initially), why these codes are in there twice is beyond me - but the FPCM has priority so when it triggers a code, the CEL comes on.
Damn I wish I would have actually looked through the forums 8 months ago… now I want a new fuel tank and alm stage 2 to get rid of the hole in my tank from the Dsx kit!
2014 CTS-V Sedan A6
Same, but I've had a DSX Aux for a few years now. I just put this hat in yesterday and ran a new 6AN line to the engine bay and ripped out the stock metal lines. My aux now has it's own 6AN line, and they both meet up to a 8AN where they pass through a bypass flex sensor then split to 6AN to each rail.
I think in the future, I'll replace the gas tank and drill this hat to make a passthrough for my aux. But this is because I plan on dropping my rear subframe and have it stripped and repainted. I love my car so it gets all the good treatment.
Reactions: random84
I also got the stage 1 hat and see there is a provision to add the auxilery fitting. Appears to be spot drilled at the location the stage 2 places it.
Of course the hat would need removed to be drilled and tapped for the an fitting.
2014 CTS-V Sedan A6
Yeah, super easy to mod for a fuel passthrough. And like you said, you could tap it and not need a bulkhead fitting. It would seal real nice and be super stable.
Reactions: jcs003
All the same.
You don’t need more hose length. Just the additional -6 90 adapter on the top side, only thing Not included.
So if I just get a new stock tankard use your stage 2 my Dax hose will work with a 90 fitting?
Yessir. A low profile 90 deg adapter so that the hatch can fit.
Thank you sir I will be getting you hat soon I just had a buddy give me a good new to me tank out of one of his wrecked sedans and it doesn’t have the hole drilled like mine!
21 - 40 of 43 Posts
