1 - 1 of 1 Posts
Fun pedal, Few doors
I intend to remote mount my ignition coils, likely behind the Magnusson blower, which is shaped in a way that SHOULD leave quite a bit of room back there. I plan to fab the mounting bracket(s) but thought I should check to see if any of you have a source for ready-made brackets for mounting the coils anywhere but the valve covers? (Stock coils).
Additionally, those who have done similar... did you open up the stock coil/injector harnesses and separate and reroute the existing coil primary wiring OR did you either create or buy coil connection "extensions"?
I found a few pieces at Michigan Motorports' site in JAustin's thread. More diggin to do
1 - 1 of 1 Posts
