1 - 8 of 8 Posts
So I have an 04 and my rear wheel bearing is out. I need to replace it. So here is my question every thing I see says it's 6 lug yet mine is 5 lug so what bearings do I use?
I've searched the swap posts and can't find a definitive answer
Yours should be a six lug and if it is a five lug it has been changed out. Some folks have done this to allow for a greater selection of wheels. Buy a five lug and replace it. Take your time and make sure you get everything back the same way with the backing plate so when you press it back together you have everything in place. I ended up buying two bearings since I left the backing plate off and had to take it back apart and that ruined the bearing so It cost me another bearing.
1 - 8 of 8 Posts
