- I edited this post to correct some errors -
So fun fact: the high octane tables serve as the upper timing limit in idle ranges.
Idle Timing: target / base timing for idle
High octane timing: max timing advance allowed for idle stability. So leaving this a few degrees higher than your target should help timing to keep idle stable and minimize lope. I had this matching my desired idle timing (prev posts) and you could see the actual timing advance plateau while the idle adv. continued to control idle speed.
The airflow changes are slower to react than idle timing advance changes, but still pretty quick. IMHO the most "happy" idle is where you get a few degrees of timing swing back and forth, and a smaller idle adapt adjustment.
Proportional RPM error: it takes the difference in desired RPM versus actual, and literally adds/subtracts airflow based on your Increment / Decrement Coeff. tables. A good rule of thumb is to reduce the values near "zero" in the Coefficient tables by small steps (for larger cams) so its not trying to chase perfection, and thus reduce the tendency for hunting. Change too much and it will probably go nuts - so I'd suggest small changes in the 3-5% range each time.
Integral airflow is "slower" than proportional - from what I understand takes an average of RPM error over time and multiplies this to effect idle - ideally improving idle stability over time (regardless of min airflow settings). I'd probably leave the Integral RPM error range alone here (but adjusting the integral airflow table is an option).
Think of it like short-term fuel trims vs long-term fuel trims, but for idle air control: Proportional is the STFT equivalent (working in conjunction with timing advance) - but for larger cams we want to reduce the sensitivity by "widening" the correction amounts near zero (as I show below in the attachments). Integral is like the LTFT and will adapt over time to adjust total airflow, my reading suggests this will happen in spite of your "min airflow" tables... much like fueling and fuel trims.
In summary, I'd suggest for larger cams lowering the Proportional Increment/Decrement Coeff tables near zero (so there is less airflow adjustment for small RPM errors), to make it more forgiving - and potentially increase the RPM error by 5-10 RPM at most. I think the keys is to mute how much is adjusted, rather than widening the allowable error, but every car may be different. I would leave the Integral RPM error amount alone, save for lowering the corrections at and near Zero to make it more forgiving.
