1 - 4 of 4 Posts
Happened four times now in a couple weeks -
When turning off the ignition and opening door the radio is staying on. First three times it stayed on for maybe 3-5 seconds, but this morning much longer.
Could a weak battery be the culprit, or something more gremlin?
Sent from my Pixel 3a using Tapatalk
There is a switch in the door for this that will fail. Mine did this as well as a local friend. He had his fixed. A second open always worked for me.
Good to know. Years ago I had the issue with the push button actuator (coupe) and that was an easy fix thanks to this forum.
Mine has done this a few times as well. Thanks for the solution!
1 - 4 of 4 Posts
