1 - 20 of 268 Posts
R1 Concepts- Carbon Alloy GEOMET Rotors!
Manufactured for european and heavy vehicles, our High Carbon iron formulations enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability.
Each rotor is engineered to match the OE vane configuration, including OE split-core technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure. The smooth finish will improve air flow as well as reduce the amount of machining require in or to properly balance the finished rotor during the mill-balancing process.
Fine Turned
Next, the castings are sent to our state of the art machining facilities, where each rotor is machined to the tightest tolerances available in the market today. We can guarantee specifications of .010mm disc thickness variation (DTV) and .050mm maximum lateral runout. Though in practive, we regularly achieve .007mm DTV and .025mm maximum lateral runout. Then, the rotors are fine turned to a maximum of 1.6 RMS. The objective of these strict tolerances is to create the smoothest possible finish, which improves initial break-in due to the increased contact between the pad and the rotor.
After all of the machining processes are completed, each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free.
2009-2015 CTS-V
FT/RR CARBON ALLOY SLOTTED GEOMET ROTORS: $355 SHIPPED
FT/RR CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $325 SHIPPED
FRONT CARBON ALLOY SLOTTED GEOMET ROTORS: $190 SHIPPED
FRONT CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $155 SHIPPED
NEW UPDATED PRICES AS OF 10/14/2020
FULL CAST DESIGN FRONT ROTORS
BRAKE PADS
FT/RR R1 Optimum OE Pads (similar to OEM): $70
FT/RR R1 Premium Ceramic Pads (low dust): $60
FT/RR R1 Performance Sport Pads: $135
Are these "better" than the more expensive R1 rotors?
It's my understanding that these replaced the older premium rotors with the black hats. Now if I can just get mine shipped, I was told they got backed up during the switch so it's been a over a month now. I guess if they are better then i can wait.
Discussion Starter · #4 · (Edited)
Yes, these are an improved and new version of our Premier rotors with the black center hub. These rotors pretty much have a stronger and longer lasting rust protection coating (Geomet) that comes OEM and most vehicles. These may not look as nice as the Premier rotors but are an overall better rotor. Pricing is at a low price since it's a new product that we're selling and we'll soon be phasing out the Premier rotors. However this price is only for a limited time!
Can you please PM me your information so I can double check on your order your placed with us?
Yes, these are an improved and new version of our Premier rotors with the black center hub. These rotors pretty much have a stronger and longer lasting rust protection coating (Geomet) that comes OEM and most vehicles nowadays. These may not look as nice as the Premier rotors but are an overall better rotor. Pricing is at a low price since it's a new product that were selling and we'll soon be phasing out the Premier rotors. However this price is only for a limited time!
PM box is full.
Prices will go up back to original Premier pricing after Wednesday! Be sure to take advantage of this sale while it lasts!
Sign me up for a set of four... PM inbound
1 - 20 of 268 Posts
