Status
Not open for further replies.
1 - 20 of 393 Posts
R1 Concepts Inc. is proud to offer Premium CTS-V Rotors!
I am offering the Premium series rotors which are made with stronger iron cast metal (XG3500) for overall tension strength. The Premium series rotors which is the top of the line series out of the two that I carry (E-lines & Premiums). The rotors are cast with a 50/50 center split for better heat distribution. Premium utilize a black Electro-coating finish applied on the hubs and inner vane structures providing long lasting corrosion protection. Original stock size, will bolt right up with no modifications needed. (we also have our E-line series available)
What separates R1?
Often Imitated, Never Duplicated. Here at R1, we take into account numerous precautions in machining rotors. We drill our rotors in house using state-of-the-art CNC machines and follow strict procedures and standards such as drilling between each vane structure. This will allow the rotor to retain its structural integrity and overall strength with optimum thermal transfers. We utilize smaller diameter drill bits for smaller diameter holes and each hole is counter-sink to add strength. You also have the option to go with slotted only or even a custom design with your own logo. Every R1 rotor that comes with slots will come with our exclusive "Diamond Slot design" (45 degree angle end points), to help release trapped debris. Our diamond slot design is also a good indicator for rotor wear. We also offer optional Cryo Treatment at an additional cost. (Cryogenic treatment is a process that improves the performance and life of the rotor by strengthening the metallurgy. This process will help to give an extra level of protection against warping).
*WARRANTY*
Here at R1 Concepts Inc, we stand by our products. We offer a one year warranty on warping and cracking on all R1 brake rotors due to manufacture defects and workmanship.
AVAILABLE STYLES
Slotted Only
Drilled and Slotted
Drilled Only
Dimple and Slotted
Custom/
Engravings*
(ft/rr = front and rear)
(*engravings cost may vary)
04'-07' CTS-V
FT/RR Premier Rotors: $425 Shipped!
(AK, HI, and International will cost more)
09'-13' CTS-V
FT/RR Premier Rotors: $475 Shipped!
FRONT Premier Rotors: $250 Shipped!
*Optional Cryogenic Treatment: $30 extra per rotor
04'-07' Pads
FT/RR Posi Quiet Ceramic Pads: $80
FT/RR Hawk HPS pads: $155
FT/RR Hawk Ceramic pads: $200
FT/RR Stoptech Performance Pads: $115
09'-13' Pads
FT/RR Posi Quiet Semi-Metallic Pads: $100
FT/RR EBC Redstuff Pads: $230
FRONT EBC Redstuff Pads: $150
FT/RR Hawk HPS Pads:$220
FRONT Hawk HPS Pads:$125
FT/RR Hawk HPS 5.0 Pads: $250
FRONT Hawk HPS 5.0 Pads: $145
FT/RR Hawk Ceramic Pads: $240
FRONT Hawk Ceramic Pads: $145
**ALL OTHER HAWK PADS AVAILABLE TOO! PM FOR PRICING!**
Brake Fluid
Stoptech STR-600 Brake Fluid (500mL): $16
Stoptech STR-660 Brake Fluid (500mlL): $24
If you are interested, please send me a pm for ordering instructions.
Kevin C.
1-888-712-6623 x7022
[email protected]
Kinda hard to beat $600 cryo treated rotors.
Much better title!!
Reactions: R1CONCEPTS
Much better title.. love my R1's!
Sent with my Galaxy Note II
Are these the exact same sizes as the stock rotors?
Sent from my LG-D802 using Tapatalk
Not sure one could get away with something that was bigger or smaller than stock without other supporting size adjustments.
These would be stock size and replace the stock rotors.
My thoughts exactly but I may have read somewhere these rotors are a tad smaller in diameter than the stockers. Or I could be wrong.
I may be due for new rotors and pads soon. Subscribing as a reminder. Thanks. '10 V sedan if you pm me with any info.
Sent from my EVO using Tapatalk
1 - 20 of 393 Posts
Status
