1 - 6 of 6 Posts
2012 CTSV coupe
Installing my ID1300's. Am I correct in assuming the factory injector retainer clips are not used on the fuel rail?
2012 CTSV coupe
The diameter if the ID injector seemed to be too big causing the clip to be pushed out enough to not engage the lip of the fuel rail.
I have 1300s..they fit but I am using the adapters that have their own clips....if that helps.
Are you sure you have the Injector seated all the way into the rail? and once it's in, the clip should go right in the slot (which is clocked on the injector), you may have to rotate the clip to align with the slot. I'm referring to the ID 1300 that are same as OEM.
Good Luck
2012 CTSV coupe
Discussion Starter · #6 ·
Thanks for the quick responses. I wasn't getting the clip in the slot in the injector.
1 - 6 of 6 Posts
