Too many variables for a good answer.On average how much different are your times on a prepared track surface vs your times you've measured on drag radials, on an unprepared street surface? 60'? 1/8? 1/4?
With M&H drag radials best prepped track 60' was 1.49 hooking. 60' on the same radials at the same track, unprepped, was 1.77 spinning.Also curious.
And wondering about 60' times on prepped vs unprepped tracks
And suspension requirements, deffer greatly between the two. . . .Agreed there’s a lot of variable at play in order to scientifically answer this. But prepped track vs unprepped definitely makes a difference in traction. Trying to translate that to the street is kind of hard. Concrete? Asphalt? How much power the car makes etc all play a big factor.
I would kill for that time. Unprepped track my best 60' with drag radials is 1.95. I'm consistently around 2.0x.With M&H drag radials best prepped track 60' was 1.49 hooking. 60' on the same radials at the same track, unprepped, was 1.77 spinning.
I checked my logbook before I had DR's and on an unprepped track with stock 19' tires I was able to 60' 1.9xx ish albeit spinning, so your results sound about right.I would kill for that time. Unprepped track my best 60' with drag radials is 1.95. I'm consistently around 2.0x.
Gotta get there on a night when they prep.
