1 - 16 of 16 Posts
I don't know where this is coming from? I just got my car back from the performance shop. Anyone have this happen to them? :confused:
Dick Pickles
Check to make sure your power steering res is full.
Discussion Starter #7
Discussion Starter #8
My car made the same noise. Turned out I didn't clean the pulleys good after coolant spilled out when changing the thermostat. Noise went away after I replaced the belt. Once the belt is contaminated with coolant, oil, or other residue it will make that squealing sound. Try running a bar of soap on the groove side while the car is running and see if the sound goes away.
Dick Pickles
That's a good thought!!
The PS res doesn't need to be really low to make some crazy noise.
If you installed a 100mm idler pulley check to see if it's touching the pulley directly next to it.
Sent from my KFTT using Tapatalk 2
Discussion Starter #13
Found the problem. We had to replace the belt. They said something fell on it, in other words it was dirty. No biggie.
Dick Pickles
Sweet! I'm glad it was an easy fix. Thanks for thee update. :)
Had a high pitched sound coming from my "11 coupe twice in the last couple of days.
First time I heard it I thought it was a police car or emergency vehicle.
Pulled over and rolled down the windows and it was really loud.
After a few minutes it quit.
Same thing happened the next day. Took it into the dealer yesterday.
Got a call from the dealership last night, they are replacing the supercharger under warranty (19,900 miles on car)
Discussion Starter #16
They had to replace mine as well under warranty. Kinda kool because the charger is what usually gives out before engine. Now we are on the up and up.
1 - 16 of 16 Posts
