1 - 13 of 13 Posts
I finally got around to installing the Prospeed Bumper tank, but I cannot get the lack of a pressure relief off my mind. I am debating having a 1/4" nipple welded on toward the top of the fill neck and adding a low pressure adjustable pressure relief valve. Using the inline piece below would allow for it to be routed to a container in case it vented more than just air.
Straval Inline Pressure Relief Valve <LINK>
Have you guys done anything on your systems to relieve excess system pressure like the OEM T reservoir did?
That would definitely work, I’m hoping to not have to neck down the diameter for the T though. Next step in the plan is all 1” lines with the AR Hobbs brick.
Are you focusing on water flow or heat dissipation?
Keep your eye on the prize, and do not over-pressurize the brick.
My current concern is relieving head pressure. After that, I’m just focused on whatever keeps me from hitting 140* IAT2 in summer.
I also had issues before with the EMP pump pushing fluid out the overflow line so I’m hesitant to reintroduce it in the system.
Ahh. You have an EMP. Ok. You can get a tee that will accept a radiator cap with a low pressure rating. Or fashion a relief valve and a hose to drain where appropriate.
I like the idea, not sure about the one you selected, I was thinking something more like this,
I ended up venting mine by adding a bulkhead fitting and hydrophobic vent filter, but I have an underhood tank where it is the highest point.
I wanted to get rid of any back pressure in the system thinking it would pump better, but because it is a loop the back pressure would also provide pressure on the suction side so maybe it doesn’t really matter, I was going to add a vortex flow meter to measure if there were any differences but not sure worth the time and effort.
Vortex flow meter….if your fluid is conductive, a magnetic flow meter would be better because:
-Vortex require 10 pipe diameters upstream, 5 downstream, of straight run
-there is some pressure drop across the shedder bar
If the fluid isn’t conducive, magnetic won’t work, period.
The testing I did years ago was using a magnetic flow meter and tap water.
There are less expensive and more expensive options.
Discussion Starter · #9 ·
I don’t think even my hotrodded EMP would move the needle on our Coriolis meters at work. They’re also calibrated to something with a little higher gravity than my coolant blend haha.
Coriolis meters have incredible turndown. I’ve run them 1500:1 turndown ratio at better than 2%.
They are calibrated on air and water and have a straight line calibration from 0 to 5 g/cc, and the uncertainty is, depending on manufacturer and model/series, 0.01-0.0002 g/cc.
Basically, on water, better than 0.1% on the better models.
I use a 5psi "radiator" style in line relief- a true 3/4" style with cap and you can find them on eBay.
Definitely need a pressure relief for an under hood system. The stewart can move some fluid and it can cavitate if not run with a reservoir.
Sorry I mis spoke I meant a simple mechanical variable area flow meter like this, wasn’t thinking it needed to be that accurate just to see if there was a difference in different setups.
Reactions: random84
1 - 13 of 13 Posts
