1 - 2 of 2 Posts
I'm curious to know where everyone is at with their PE. How and when are you enabling it? By how I mean, are any of you still using the hot throttle table, or just MAP based enabling?
i use mainly the TPS as the trigger as its the first sensor to trip it, i will add in the MAP value if it does go into PE too early for some instances, ill have it so im driving around normal in CL but soon as i want torque its there usually bout the 40% actual throttle (bout the same time i make boost)
1 - 2 of 2 Posts
