2012 coupe with nav. I usually ride with my radio/nav pop-up screen down. Lately it has started to randomly go dark. Nothing else seems to be affected. The radio continues to play, the enviro system seems to function, bluetooth is good, steering wheel controls work etc. It's like the screen just goes to sleep. It's not usually out for long and just as randomly, it will wake back up. When I push the nav button the screen comes up like it is supposed to and wakes up. I have not observed it doing this with the screen up, only with it down and I swear, I believe it does it more the first few minutes after I crank the car. It doesn't matter if the car is sitting or in motion and when it's out, it doesn't respond to the touch screen. Trying to jar it doesn't work either, so it seems like it's not just a loose connection at the display.
I did a search here and I found the post about a bulletin for the 09-10 with nav having a problem with the display flickering caused by a connection at the fuse box, but mine doesn't flicker. It's on or off. Anybody have any ideas before I go blindly into tearing my dash apart looking for a bad connection.
TIA
TIA
