I've been struggling with my current setup & wanted some input to validate what I'm seeing is OK.
My boost seems too low for the pulley sizes & engine mods.
This is my first roots build that wasn't an aftermarket bolt-on style kit.
Base info:
LS3 with stock LSA charger
Boost control solenoid is not used.
ZL1 lid
218/232 Cam
Stock heads
92mm cable throttle body
4" intake
Killer chiller intercooler with no HX
1-7/8" headers & dual 3" cutouts
Initial testing was to confirm basic functionality:
Using a 10% lower with no cooling, I was getting 160kpa boost & 160deg temps on a short burst.
Cruise air temps were 20deg higher than ambient before any heat soak.
Once I got the chiller functional, I was able to safely make some longer test runs.
The boost was typically 150-152kpa maximum with it peaking at my 6500rpm shift point.
There consistently seems to be a 1-2kpa bump at peak rpm.
IAT readings in the lid were starting in the mid 60's & finishing in the upper 80's
The cold water seems to be reducing the boost.
The latest is with a 22% lower & stock upper pulley.
Air temps went from 64-104 in 1/4 mile.
The max boost is still only reading 170kpa.
I removed the air filter to see if it was a restriction with no change in boost.
I assumed a slipping belt or inlet restriction would cause a drop on the top end.
I have a 100lb injectors hitting 70% duty cycle at 11.3:1 AF ratio on 93.
Traction is currently a problem in lower gears so I cannot get a good ET, but it accelerates from 100-125 in 3.2 sec according to my data log.
Base info:
ZL1 lid
218/232 Cam
Stock heads
4" intake
