1 - 3 of 3 Posts
So i got my car retuned yesterday and swapped my plugs out for BR7EFs along with adding a NGK wideband kit. Did a bunch of road tuning and dyno pulls no codes. Then left to head home on my 4 hr drive did a lil 1-3 pull and noticed a code a few minutes later. Brought it back around and read a P069e and P0231 code. Cleared them and noticed it 10-15 min later after a lil spurt of 100 mph constant driving no full throttle.
Now the car runs great(drove 4 hrs home with the code), even just a lil rich at the top near redline so i don't think the pump is failing (64% IDC). What could be throwing the code all of a sudden? Does anyone have the wiring layout for our Fuel Pump circuit?
P0231- LOW VOLTAGE FUEL CIRCUIT
I had the same codes come up with my CEL. Are you running E85? Dealership said the FPCM had an issue and replaced it, haven't seen it come back since.
Discussion Starter #3 (Edited)
Pump gas, only change to fuel systems is injectors and only a wideband is wired in otherwise nothing electrical has been done. Maybe ill see if i can get the dealer to cover under warranty i still have bumper to bumper.
Just wanted to know if there was anything i could reset or swap easy to test if it is the module or just a fluke.
1 - 3 of 3 Posts
