1 - 17 of 17 Posts
New here and to the caddy. So quick question what would cause the fans to not come on. It gets up to about 220-230. The previous owner says it has an ls2 not the ls6. Also told me it's an 08 engine.
If it's a swap I wonder if he messed something up with the harness, I don't recall what ecu pin the fans are, but you could check the fans with a jump box to verify they work, check the relays etc... Also see if the fan turns on with the a/c.
If it's an 08 engine and doesn't have a crank sensor converter box, or a new ring on the crank, it would need a newer ecu as well.
So I checked the fuses. They are good. The 2 30 amp square fuses. Not sure how to check the relays. Could it be the temp sensor? But the gauge and display work fine. The gauge sits in the middle.
Did they make a cts-v in 08. Every time I googled it the years went from 03 -07 then 09 -to present.
Easiest way for a novice to check the relays would be to pull the relays out, pop the plastic cover off, put them back in and manually move the switch to see if the fans turn on, then you can check the trigger power to them if they do turn on, or if they don't you can start by checking the constant power to the relay, direct power to fans, and so on.
I usually start at whatever component isn't working and work my way back to the power source.
Or you could just figure out which terminals on the relay are the contacts, pull the relay from the block, and jumper those spots on the female connector.
What year is your V? 06-07?
06-07 V1's came with LS2.
No V was made in 2008.
Discussion Starter · #10 ·
It's an 04. Supposed to have 08 suspension and engine. But like you said they didn't make one in 08. So I need to get the numbers off the block to find out. But the overheating is problem number one.
You could and should pull the relay n jump the terminals, but if you don't understand how a relay works that could end badly lol.
Discussion Starter · #12 ·
I know how they work. Just new to the caddy and didn't know if this was a common problem or not.
He has an 04 V with an 08 LS2 engine and 08 suspension. Don’t know where he got the 08 V suspension.
Discussion Starter · #16 ·
So I had a friend hook up his snap on computer and he turned on the fans but when he turned them on on the low setting they both came on but on the high setting only one came on. Is that normal?
That'd be opposite. That said I have seen some protocols in scan tools be labeled incorrectly. There are just so many vehicles they have to account for sometimes they miss the mark.
Sounds like you need to plug in with hptuners and check to see when the fans are set to come on.
1 - 17 of 17 Posts
