1101 - 1120 of 1149 Posts
2012 CTSV coupe
Did they hit even with the thicker valve cover gaskets? What made you go to a 1.8 rocker? Did you work out the effect on cam duration and determine it was beneficial?
Discussion Starter · #1,103 ·
Yes, I was using a thicker gasket that cleared on mock up. Rockers are only kissing where the baffles are pressed or glued onto the valve covers.
New covers clear by another 1/4" so no more problems. If anything, the gasket just compressed over time I guess.
Discussion Starter · #1,104 ·
Just for curiosities sake; What is the Rocker Arm Ratio for the exhaust side?
Here are the valve events for your camshaft:
Do they include the 1.8:1 Intake RR on the intake
side?
Cam: 234 / 252, 0.641 / 0.648 lift, 119 lsa
So with a 1.8:1 Rocker Arm Ratio, that would
put the 'Lobe Lift' at only 0.356". . .
So know continuing to become 'Nosy..lol' what is the
Cam card
Cam card
Yes, that data agrees with my post just above, regarding the intake lobe.
***I did not bother to calculate the exhaust lobe lift.
As I said. . . .Interesting. . . .
YT rockers have come a long way. I've been running 1.7 YT RRs for about 11K miles. Also, ebay LSX valve covers work awesome. The noodle like gasket that comes with them is trash, but OEM and a little RTV to hold them in place works great. The are around $100. You just have to relocate your coils.
Discussion Starter · #1,107 ·
Yeah, but you say "interesting..." like there's something I should know!
Yes, that’s very interesting...
Discussion Starter · #1,109 ·
The upside is I discovered a very small oil leak at the rear of the valve covers - so that's fixed. And I like the look.
Looks like you have a small kink in one of your heat exchanger hoses. Might wanna look into that.
I think yella terra got a bad name from that batch they made sometime in the early 2000s. Of course I ended up with a set of the bad ones lol. I switched to harland sharps.
If your into this type of thing, then check the 'Actual
Rocker Ratio' at the valve, on all sixteen rocker arms.
Harland's rocker arm ratios are not always what they advertise. . .
If they are not the same, then 1) the valves won't be lifted
the same.
And (2 the sweep across the valve stem won't be the same.
Reactions: random84
You wrote:
'The upside is I discovered a very small oil leak"
Fascinating, as I never liked oil leaks, glad you do..;)
Reactions: random84
@rubberduck
Yeah I had my machine shop guy check them, I didn't want to use them but at the time that's what I had available.
Sucks because one of them got a little beat up when I lost a spring. Good luck finding just one. It still runs fine just bothers me that it's in there.
I can't tell you. . or I would, so to speak. . .
Proverbial Phrase coming now. . .
'I would have to kill you'..:eek:
Most on this forum should not go this route (JMHO)
***Most on this forum need to deal with someone like
Matt, who have proven designs. This is exactly why I
came down on Mr. Surely so hard about a week ago.
***As I stated; he seems to understand engines.
But what about those who don't, so why attempt to
steer people who only possess limited knowledge,
'Away' from another cam company, who does not?
I will further state; if one does not have Titanium Valves
and a 'Stout' valve train, one should not do this. . . .
If I thought people would invest in such things, I would
have designed a camshaft that would add about 50fwHP
over most others (minimal 25fwHP), which would 'Really'
increase the 'Lobe Area' on the intake opening side of the
lobe. Which is exactly what these engines require.
***I was asked to do this some years back. I considered
it, but decided it would take too much of my time
counseling people on everything, which would be
required to make such a camshaft work.
***Also, the popular valve springs used by most
companies for this platform, won't work! So much of the
engineering I would have had to perform, would have
caused me to make phone calls to spring companies,
who were capable of helping me design the correct
springs.
Spring pressures; both over the nose and seat pressures
simply are not good enough with this type of cam.
I would have to have worked out the 'Spring Rates' at
each degree of valve opening. Too much time!
-summarizing-
Adding higher value rocker arm ratios, to an incorrectly
chosen lobe, is really not the way to do this.
***Jesse, I am not saying your lobe is incorrect.
Frankly, I don't know and don't want to go there. . . .
Current camshaft designs for this engine
platform don't increase the acceleration
rates of the 'Lash Ramp' nor the 'Lobe Flanks".
Why. . . If not done correctly, much damage will result. . .
The current methods to increase 'Area Under The Curve'
only uses lobe duration.
This causes the LSA / LCA to be widened far too much,
which then moves the ICL, to a far too large a number. . (JMHO)
And for the newcomers to this forum; stay safe and
use already proven designs. I recommend going
to people who build these engines, have build them
for a long time, and also who have proven Dyno
Data. This helps to prove their ability to both produce
HP, as well as reliability. . .Reliability with these
engines is directly correlated with how to tune
these engines.
Feeding fuel and air to these engines is not
exactly straight forward. . .
Take care Jesse!
Bruce
springs.
-summarizing-
And for the newcomers to this forum, stay safe and
Data, which proves out their ability to both produce
these engines.
Take care Jesse!
Bruce
So Jesse,
Are you moving over to the Kong Lid, and / or E85?
And 'NO', I am not worried about your 'Damn Wheel'. . lol
Discussion Starter · #1,117 ·
So Jesse,
Bruce, I already run ethanol - and I am running out of pump on the high end when full e85. So since I am upgrading the fuel lines for flow, it's easy enough to swap rails to accommodate the Kong lid. With more fuel, I can push more pulley ratio, since I can "handle" it with e85.
I am probably going to get the Kong lid just for shits and giggles after messing with the fuel lines, but Greg acts like the big gain is durability, and potentially some cooling from the dual bricks, but he's really not selling "power" improvements. I might risk one more dyno pull when it's all said and done just to see if it's 4 digits. :D
I'm not sending u ur nu muffles till I see a video of ur car making a full pass on a prepped track with the drag radials on. Git r dun.
Please remind me. . .
Was the ~835 rwHP made on a quality E85?
If the Kong Lid has more 'Brick Area', then it will
benefit, 'If' you can also push more coolant through
the increased 'Brick Area'. . . .
If you end up pushing more coolant through
the Kong Lid and the IAT's don't come down,
then put a restrictor at the output of the Bricks.
This might benefit you in two ways. . .
1) Stop cavitation
2) Slow down the coolant so it absorbs the heat.
If the ~835 rwHP was made on a quality E85,
what was the 'Peak Torque' and at what RPM?
What was the timing / advance at 'Peak Torque'?
That ought to keep you busy for a day or so. . lol
I look forward to the info. . . .
Take care Jesse!
Bruce
Discussion Starter · #1,120 · (Edited)
I don't blame you for holding them hostage - in my defense I had a track rental scheduled last year before the Commies gave us all Covid. I've even opened up a facebook account specifically to get back on the V groups, to catch the next one... and sell parts. :D
1) Stop cavitation
Take care Jesse!
Bruce
Bruce,
the ~835 RWHP was on a dynojet, and ~15% ethanol, so basically pump gas. EDIT: I never actually got the dyno graph - it was my birthday last year, as the car fell off the dyno before I could get an ethanol run. So in all the drama I realize I don't think I ever got a copy when dealing with the shop and repairs. It wasn't a "clean" run as I was getting a bit of knock retard around peak torque for the pump gas run.
Regarding the intercooler circuit - I also use an underhood reservoir specifically for cavitation, as without it the Stewart EMP will cavitate and just push a constant stream of foamy coolant out of the overflow.
Edit #2:
This was the last clean run - it was 50% ethanol until a pocket of unmixed fuel worked in the lines halfway through the run (you can see the fuel % dropping and it went very lean).
