981 - 1000 of 1013 Posts
Or buy every single one you can get your hands on, and turn a fat profit when guys start calling.
yeah. might even be worth scrapping some lowly base wagons (do they have the same rear fenders? or are the V's flared?)
I was wondering the same thing...
Discussion Starter #983
Yay!
I wont bitch about the 2.55 griptech that's MIA, only because I'm not 100% certain it isnt in the garage somewhere... @adam112
But once I clean up the gasket surface and get it together check out the for sale section.
Hey man. If I can’t bust YOUR balls...then wut is this place coming to?
Glad you finally got taken care of!!
GLWS and finding the 2.55
What was wrong with it?
Discussion Starter #986
Original main shaft was not up to the task (from Gforce) and took out the snout bearing.
Jokerz had a new one machined out of better materials.
$500...
Reactions: adam112
Yay!
Jesse,, Is that a machined plate where the fins and orange rubber seal would go? I have Jokerz Chaos, and mine is not like that?
BTW, that shit sucks that happened on the dyno..
Later, Jeff
Discussion Starter #989
Later, Jeff
Yes - the TVS2300 uses a different gasket pattern for the ZR1 intercooler system (totally different than the ZL1 / LSA), as well as the snout being front-facing for the ZR1; so that adapter plate along with the custom snout is required to make a TVS2300 work on the LSA.
Discussion Starter #990
Finally got my bitch back!
Now just need the wheel.
Burnout videos or GTFO!
Discussion Starter #993
Battery didnt survive the auto repair shop - new AGM48 found.
When is it going back on the Dyno??
Reactions: Unavowed
Discussion Starter #995
Meh. Whenever I get the nerve to fuck around with ethanol timing I guess. I'm happy with an honest 830 dynojet HP on pump.
At first I realized I ordered the wrong DR size, but after checking fitment... a taller tire would probably rub quite a bit. So the tire is a bit small (and looks it) but they seem pretty damn grippy.
And yeah I might have them powdercoated after all... lol
I’m pretty sure the 295 is supposed to fit on lowered V’s. Nice center caps homo! ;)
Goin bronze to match I assume?
Discussion Starter #997
You like my bulge.
In the ET street R and S/S, the only two options are a 275 (26.1 OD) and a 305 (28" OD).
There is no current 295 size that I see on MT's website. The 305 is obviously a better choice in cross section and OD, but I didnt want to fuck around with rolling fenders as I'd like to DD these for a bit.
But... the coilovers seem to be doing a great job and I have room for adjustment, so I'll probably go 305 next time around.
275 50 17 m&h for a better fit and taller tire.
