After a WOT run I noticed some noise......clicking noise. I pulled over and noticed I was low on oil. I added a quart I had in the trunk and the car stopped making any noise. Next thing I noticed was that I had low oil pressure (6psi) at idle). Though no light came on, I was still concerned. My oil was changed three weeks ago so to be this low on oil is a flag. I finally got around to changing the oil and saw very fine powder-like particles in there, no chunks. Keep in mind this is the second oil change on this engine and the first was done at 300 miles.
I started the car this morning when it was cold and it held pressure to 38-40psi the dropped gradually as it got warm all the way down to 8-10 in operating temperature. The pressure goes up to about 23-25 under light load (2K rpm).
I am going to tear it down some and trouble shoot starting with the oil pump. I am wondering why would it hold pressure and then lose it? We are thinking it could be the o-ring at the pickup. Maybe the bolt there came loose and come to find out it wasn't locktie'd. If that's not the issue, then it is either the pump or bearings. Wouldn't it NOT have pressure to begin with though? I am hoping there's no need to go that far.
