Figured I’d start my build thread since it’s coming together quickly now. Here’s a list of everything I can remember going on or already on the car. I’m also working with aeromotive to develop a drop in fuel system for the V.
2012 V
-stock lsa block
-k1 rods
-wiseco pistons
-stock crank
-tool steel wrist pins
-btr stage 2 twin turbo cam
-arp rod bolts, cam bolts, crank bolt, main studs, head studs
-unported lsa heads with dual valve springs
-Johnson lifters
-comp push rods
-ls3 intake
-stock trans
-Huron speed twin turbo kit
-turbosmart race port bov
-turbosmart 45 lite Wastegates
-turbosmart eboost2 controller
-lingenfelter 2 step
-comp air cooled 6467’s
-billet motor mounts
-Huron speed turbo back exhaust
-ID 1700x injectors
-aeromotive prototype fuel system
-total seal piston rings
-ls9 head gaskets
-aem obd2 wideband
-trunion rocker bearing upgrade
-ati harmonic balancer
-e85
2012 V
-stock lsa block
-k1 rods
-wiseco pistons
-stock crank
-Johnson lifters
-comp push rods
-ls3 intake
-stock trans
-ID 1700x injectors
-ls9 head gaskets
-aem obd2 wideband
-e85
