1 - 4 of 4 Posts
This set up is something I had on my 09 Sedan for 3-4 yrs. I wanted the wheels to be flush with the fender and this is the set up I ran. I bought these new from Detroit Wheel they are PVD Brite finish. The fronts are Sedan 19x9.5 OEM rears with a 10mm hub centric spacers custom fabled. The rears are Coupe 19x10 OEM with No spacer. So this set up will work on coupe, sedan an wagon. I will also include chrome solid lugs.
These wheels are very clean zero curb rash! Minor scuffing from replacing the tires and some road wear because they have been used. The rims are true and not bent or damaged. The rear tires Conti DW still have life 50%, however the fronts are dead due to the known V alignment smh..
Prefer local pick-up or close in N Fla, I'll work with you.
Tx me for quicker reply. 904-400-8503
Thanks, Jeff
Sent from my SM-G960U1 using Tapatalk
V Coupe Pedal car
Interested in a Satin Graphite Coupe set?.....
Discussion Starter · #4 ·
Ha. No thanks. Have too many wheels.. you interested? I'm entertaining offers.
1 - 4 of 4 Posts
