I'll take a closer look when I get into the parking garage after work. =D Thanks.its very easy, the whole process takes no time at all
just wipe them down and spray bomb them. Hang them with a piece of string or wire
take you longer to let them dry before loading the new refill in
TRICO - Windshield Wiper Blade Refill: 45-190Does anybody have a good source for the wiper blade refills/inserts (the rubber piece only)? I was able to detach the rubber portion from the rest of the wiper assembly, but couldn't find the correct refill anywhere. I measured and they're 19" and 22".
Thank you!TRICO - Windshield Wiper Blade Refill: 45-190
TRICO - Windshield Wiper Blade Refill: 45-220
Both passenger and drivers side. I got them at O'Reilly's
https://www.amazon.com/Genuine-20825882-Window-Wiper-Blade/dp/B00GU9V8FGAnyone know the blade window for rear replacement on wagon?
I know its an old thread but i need to do this, my Wiper blades hv been toast 4 a while but i was dreading the aftermarket replacements.you dont even need tools, they just bend and hold in place with tabs on the refill
before you put the refills in Shoot the blades with some semi-flat krylon while they are off and they will look brand new again
