Nord lock or Gev washers
909 Views 7 Replies 4 Participants Last post by  Spearfishin
Which washer is better to use on a lowered sedan. Tired of going thru front tires so quick. I am hearing a pop noise front left while slowly turning into drive and also when coming to a stop sometimes. Also, how many pairs for nordlock and/or how many Gev washers for front and rear. Thanks fellas
1 - 8 of 8 Posts
When I inquired about Gev washers he said not making any, not sure when he would again...of that helps your decision making (or perhaps you've reached out and he has some).
I used 4 each of the two below (so one package of each):
Zinc-Flake-Coated Steel Wedge Lock Washer, for 5/8" and M16 Screw Size, 0.67" ID, 1.21" OD
McMaster-Carr
Zinc-Flake-Coated Steel Wedge Lock Washer, for 9/16" and M14 Screw Size, 0.60" ID, 1.210" OD
McMaster-Carr
I cant recall the details at the moment, but I got mine from WWGrainger and I recall they were a bit less pricey than McC.
McMaster is just my "easy button" when I'm in the garage and decide I can't move onto the next step until I have "XXX". Pull up the app, eat the overpriced product and $10 UPS shipping for a 4oz package, and it's on my doorstep in one or two days.
Understood. Mine is McC and also WWG and usually BOTH are stupid expensive...howEVER... somethimes I'll get a shock. WWG, I order online, day or two (usually one) I just pick it up on the way home, no freight. McC doesn't have any locations handy for me.
I've been trying to contact GEV on his washers for a while now, he says his machinist is being a flake, and I don't even know if I should give up on getting those now. He did say he ordered several hundred from his machinist. No telling when he'll actually get them though.
McMaster-Carr
I take it these are not the Nords but something else? I may go this route then. Are they wider than Nords? I think that is why I wanted to get the Gev's in the first place - less overall stress on the subframe. If these are the ticket then I'll get em
I think they are identical minus the branding. Car has only seen a thousand or two street miles and 2 days on the road course since they were installed, but no indication that the alignment has slipped at all.
1 - 8 of 8 Posts
