New Whipple 3.0 for LS @RubberDuck
3641 Views 19 Replies 7 Participants Last post by  AC Promotions
Reactions: 2
1 - 20 of 20 Posts
I'm just glad companies are still making new products for our platforms. I wonder why Whipple haven't adapted their new 3.8 blower for this platform. Not that many of us could use it as it would probably require an aftermarket block and the best of the best rotating assembly to maximize it.
Reactions: 2
  • Haha
Reactions: 5
Well I stand corrected then! lol...my paltry Compstar rotating assembly would probably twist like a pretzel if I tried to run a Whipple 3.8! :LOL:
Weeeelllll...I have a block and rotating assembly rated for 2,000 hp on the way.
Reactions: 4
I actually called Norris after watching that video, purely driven by curiosity.
As I'm building a 427 LsX now, I inquired what it would cost to do the Whipple on my long block. First you have to know that the front accessory system is all custom and designed after the Camaro spacings/locations and no, it won't fit in a V....
He said he could take my new (built for boost) long block , install all of the front accessory drive and the Whipple, tune it on the dyno using Holley aftermarket EFI system and then (I'd need to translate the fuel trims into HPTuners etc) and then making the whole thing fit into the V would be my problem... Six months and 17 grand.
He would not give me a price on the blower
That's today's market!
*ME, TOO!
Reactions: 4
^more like that’s first to have it kind of thing market
Would def be a big bump over a 2650 though? Nearly double the stocker.
That is definitely "early adopter" pricing.
Thank you much my friend.. :giggle:
Everyone please take note:
Engine used E85. . .
427 CID Engine made 1200 HP.
=> (1200 / 427)= 2.88 HP per CID
That's pretty 'Stout'!
If the engine is efficient, on Gasoline, it would take about 492 cfm of flow per cylinder head to achieve that number.
***492 CFM would amount to about 1968 CFM of output flow from the blower, corrected to ambient temp.
By using the E85 that number is significantly reduced as the E carries Oxygen with it, which is moved into the cylinder not via the cylinder head (in it's typical fashion), but by the fuel pumps.
*ME, TOO!
Go For It. . .It Might Just Work..:giggle:
Worry not….i don’t wanna wait six months!!!
I also don’t have 17K but I’d rather blame it on the calendar
Reactions: 4
You’re in the right spot “parts and planning” phase - heck, send it. But I think the little 1.9 still puts up a fight, so I’ve read. I like the 2600/2650 bc of the relatively simple drop in - that 3.0 doesn’t sound so drop in for that price!! Well, drop off and someone will drop it in!
Reactions: 3
The Whipple 3.0 is 1.3" taller than an LSA so fitment may be an issue!
Might have to bend that silly strut brace a tiny bit… __/—————\__
Here's another link; this time from Wegner Motorsports who sells a crate version.
1164 HP 376ci LS3 3.0L Supercharged Engine built Wegner Automotive! | Engine Dyno - YouTube
Began to watch the video and it was less than informative.
Anybody know what the fuel was?
Back to the end of the line then… Lol
Here’s the Wegner link to the crate engine; no mention of fuel used in the description so the assumption is it’s gasoline. I had called on this crate and they didn’t mention E or race gas.
1 - 20 of 20 Posts
