Check the Electrical Ground under the Airraid for corrosion. When it gets bad enough the Air Suspension Faults.
That is the sound that mine made after the dealer put in the wrong oil. Disappeared when they replaced it with the correct oil.Hmm, starting to notice a groan like a whale call whenever I'm making slow, sharp-ish turns. Diff?
Looks like I'll be doing a diff oil change soon. That's a bummer on no glass break sensor. I'll have to see if there are OEM add-ons for the alarm systemThat is the sound that mine made after the dealer put in the wrong oil. Disappeared when they replaced it with the correct oil.
As for your alarm question, no I don't believe there is a glass breakage sensor.
I got $33k for my 09 two months ago 61k miles. Had to hold out a couple months.Manual? What did you pay for it? I have a 12 sedan too with similar miles. Wondering what the market is now
Fully loaded? There aren’t many options available on V2. Recaros is the most expensive one. Nav is on 96% of them. Sunroof is on 80% or so.I paid $25k for my 2011 sedan with 94k miles 9 months ago and fully loaded. Was in excellent condition for its age.
...and while Nav was an option on the early models, I’m pretty sure it was standard on subsequent years.Fully loaded? There aren’t many options available on V2. Recaros is the most expensive one. Nav is on 96% of them. Sunroof is on 80% or so.
I believe that was standard.Was stainless pedals an option?
Fully loaded = all of the aboveFully loaded? There aren’t many options available on V2. Recaros is the most expensive one. Nav is on 96% of them. Sunroof is on 80% or so.
This should be my last dumb question for a while, but what size bolts are on the rear diff? Or should I be expecting some kind of allen head bolt? (I hope not)
Thanks, I thankfully have a 10mm hex socket already (my truck needs it for the front diff plugs)10mm, if you can find it.
Nice write up here: Diff Fluid Change | Cadillac CTS-V Forum (ctsvowners.com)
Why not? You think the harnesses are that different for a Euro spec model? Usually they have one wiring harness backbone, and just leave unused features as a dead end connector. My Land Rover LR3 was that way. I was able to add in all sorts of higher spec options simply by installing them and plugging them into the existing harness, then giving a Starbucks coffee bribe to a service tech at the LR dealer to enable the feature in the software settings.Apparently only the European models came with the sensors. I highly doubt there is an OEM plug and play for our V's.
Motion sensor question
Dang! that is a deal. Prices seem to be going up or at least holding steady in my searching. I haven't seen anything under $30kI paid $25k for my 2011 sedan with 94k miles 9 months ago and fully loaded. Was in excellent condition for its age.
