1 - 20 of 23 Posts
2017 Cadillac CTS-V
And who the F*CK pinstriped that car?!
2017 Cadillac CTS-V
Reactions: SimplyDreamin
God those are sexy. Make sure you post some pics after install.
And please, out of respect for that car, remove the pinstripe.
No way to 100 grit! 1500 wet should do the trick. You could try a heavy cut compound first but more then likely you’ll need the sand paper
100?!
I was thinking more like rubbing alcohol and a plastic cutter, then cleaning it up, buffing, 2,000 grit if needed.
Discussion Starter · #11 ·
Well, I was sitting in the Costco parking lot tonight, looking at the pin striping, and I realized it was TAPE.....
So, pick at the end with a fingernail, get it up, and start to pull/peel......One section at a time, one stripe at a time.....
NO MORE PIN STRIPES!!!!
Just gotta go over it with some "GOO GONE", wipe it down, and hopefully it'll be good to go....
No sand paper needed!
What wheels and color? I don't want to say I'm going to copy you, but.....I might copy you
Discussion Starter · #13 ·
The one's in the first post (that's double posted!!!)
Bronze on the Crystal White is going to look amazing.....
When they get here, I'll toss them on, then take pictures.....
What's the brand?
Discussion Starter · #15 ·
What's the brand?
These are from [email protected]
2- Rotary Forged XSF-07 OR XSF-07 Bronze 20x10.5 CM
2- Rotary Forged XSF-07 OR XSF-07 Bronze 20x11 CM
4- CM [Custom Machined]
2- Front Tires 285/30-20 [Options Below]
2- Rear Tires 305/30-20 [Options below]
4- Original 315 MHZ GM TPMS Sensors
4- Touch-Less Mounting
4- High Speed Road-Forced Balancing
1- Kit Gorilla Black 14x1.5 Lugs w/key
4- Shipped
- with Continental Extreme Contact Sport
2017 Cadillac CTS-V
Lot more width and offset options in 20". I had good luck with mine till recently. If you're in the pothole-less south, you'll probably be trouble free.
Discussion Starter · #17 ·
Well, based on your experience, and common sense, I am NOT selling my stock tires and wheels.....
At least for now.....
Discussion Starter · #18 ·
I'm so dang frustrated with FedEx. My tires and wheels are within 60 miles of my house.....
They got there Saturday....And have been sitting.....
AND
FedEx is still saying Delivery on FRIDAY!!!!!!!
ARGHHHHHHHHHH
OMG!! Those are so sexy. I didn't even cared that you double posted them because I got to look at them again. Can't wait to see them on the car.
What tires are you changing out from - Sport Pilots? Be good to hear your comparison on the outgoing tires...
1 - 20 of 23 Posts
