Folks who are far more versed in this will weigh in and point you in the right direction, but I'll throw in my thoughts on a couple of general points:
- the B15 is a great choice IF (ONLY if) you want a warranty, ~stock output~ and you DON"T plan to mod it.
- Building your own is they way to go for your kind of target.
- There's a lot to recommend investing in a six-bolt build but you'll need to weigh the cost on going that route ($$/peace of mind) and that is more important the further you get from stock HP... but even at stock levels, it is still a valid consideration.
- There is a similar argument to support upgrading crank and rods above the entry-level pieces that are typically quoted
- There is, In my opinion, a somewhat vague "line in the sand" that exists around 800-850 rwHP; if your target gets over that range, costs go up exponentially because EVERYTHING has to be upgraded to achieve the big numbers AND to be able to handle that output and live a long happy life.
- Read my sig line...
- Get with Matt @Lt1z for the real experienced low-down
- Have FUN!
