Need pulley combo help for dart 427 and magnuson 2650 and ls7 heads.
2034 Views 11 Replies 4 Participants Last post by  Ttk53
Ok I have spent lots of time reading but never joined or posted before.
My build:
Dart block 427
Cali ccw crank
Carlo I beam rods
Wiseco pistons-3.8 cc
Mamo mms265 ls7 heads with 2.23 intake valves.
Mamo cam. 237 / 253 119 + 4 .675/.675
With the .060 head gaskest and 72cc heads motor will come out to around 10.7:1
I have a new 112mm tb and ddp 112 intake
I have chris1313 dual 535 pumps and id1700 injectors.
I'm still waiting for the magnuson 2650 to show up and I'm trying to work out pulley combos
Griptec offers a 3.15 and 3.0 12 rib upper
I need to figure out the lower to get orderd.
With the comp being on the higher side car will be on e85
I have not seen a lot of data on the new magnuson 2650 let alone on ls7 heads.
Let me know your thoughts
Engineering Motor vehicle Space Machine Automotive wheel system
1 - 12 of 12 Posts
What is it going in?
Depends on fuel and number or ribs.
It will be e85 and 12 rib but not looking to go max effort. Want reliable and problem free as possible.
I would go 3.0 on the blower and 9.06 on the lower for good power but not max effort
5
Automotive lighting Motor vehicle Hood Automotive tire Bumper
Motor vehicle Automotive tire Automotive design Automotive exterior Auto part
Motor vehicle Automotive tire Automotive lighting Automotive exterior Automotive wheel system
Automotive tire Motor vehicle Red Automotive wheel system Gas
Tire Motor vehicle Automotive tire Vehicle Automotive design
Well I got a 9.45 lower and 3.15 and 3 inch uppers.
Any guess on power whenever the blower shows up?
Reactions: 2
Just wondering how much interference you run into with the 12-rib setup vs the fans/ radiator, etc.
Also do you believe 12-rib is needed?
I'm going together with an 8-rib initially and expecting to possibly need 10. Hadn't considered twelve(!)
I'm sure its tight but. My buddy had a 10 rib setup and we had to buy 12 rib belts and cut two ribs off to get a belt that the v groves were right.
?? You couldn't find the correct pitch or angle ? I wouldn't have even thought of that as a possibility. Sounds EXACTLY like the kinds of problems I run into every damned day.
I experience "virginitis" all the time as "we've never seen one do THAT before" "you're the first customer to EVER have that problem with these"
2
Automotive tire Material property Tints and shades Automotive design Flooring
Automotive tire Wood Flooring Tints and shades Hardwood
1 - 12 of 12 Posts
