Karch any feedback?About to instal stoptech slotted on my car next week. I didn’t want drilled rotors myself.
Drove about 20 miles so far, they are fine as much as I can tell. I should know more in a week, but I don’t drive my car often.Karch any feedback?
That's like saying you shouldn't have to push the pads/pistons back into the caliper to install the rotors. It's a wear item. Sometimes adjustments need to be made. Does your parking brake work properly? Found this procedure to release and reset tension with a search. Maybe it will help?I don’t see how I could adjust the parking brake nor should I have to. I purchased these being told they were a direct replacement.
Interesting. Wonder if you just got a set improperly machined on the back? Although the chances of getting 2 bad parts together seems very low.Thanks I’ll give that a try. Parking brake works properly. The opening on the oem rotors is much larger than the Stoptechs to clear it.
