That's a really odd place to have wiring. I'm thinking it's not factory.
Appears to go into the rear side passenger area. I just don’t know why they exit there and where they go. I’m painting the rocker cover and saw these hanging not connected to anything. I’m not sure about the drivers side - I didn’t take off that cover. I still feel like they’re factory. Car is 100% factory - not a single aftermarket part in it.It doesn't look to me like those wires are associated with the latches. Why the fuck (pardon my language) would GM have routed the wires to the outside of the body panel way down there, when the latch mechanism is on the interior of a body panel a foot and a half higher up? Especially in an area likely to be damaged in a crash preventing the door from opening electrically. And with the rocker in place, there'd be no way to route the wires out of the area behind the rocker. There doesn't appear to be any exit channel for the wires. Maybe there was an aftermarket "halo" light in stalled in to the bottom of the rocker at one time. Does the driver's side look the same? Where do the wires go on the back side?
Sorry I didn’t mean to imply that they were for the latches. The only issue I have going on right now is the trunk says it’s open when’s it closed. I highly doubt has anything to do with these wires.I didn’t say they were for the latches they go up into the area where the latches/ seatbelt tensioner etc is. I remember the grommets and the two small wires from when I installed speakers into the the car. As stated above I believe it’s yellow and yellow black on one side and pink and pink black on the other.
You could be on to something there, my 11 has them though. Possibly for parking sensors? Just a guessCould be wiring for a blind spot sensor if your car is a 2012 or newer. The blind spot mirror sensor usually mounts inside the rear area of bumpers. 2012 & up coupes have the sensor.
Passenger side under the rocker cover. Yellow and yellow/black wire. Where do they go and what are they? Thank you!
I've seen perimeter Antennas mounted there and in bumper covers to pick up passive door locks . I would call the caddy parts dealer and let them look it up . Even if that one is gone the others will probably work .View attachment 163628
