Start by ditching the Diablo tuner and get the MPVi3 from HP Tuners. This will allow you to data log and see where the misfire is occurring. Then send that log to someone like Pat G for a real tune. It’s expensive but worth it…
Right. In the middle of switching to HPT now. I have the MPVi2 myself. Problem is I can’t scan it at the moment.Start by ditching the Diablo tuner and get the MPVi3 from HP Tuners. This will allow you to data log and see where the misfire is occurring. Then send that log to someone like Pat G for a real tune. It’s expensive but worth it…
No but it acts like that. It’s really sluggish almost like it’s dumping too much fuelMy guess is that the MAF is out of whack and needs adjusting. You're going 30mph in 5th gear???
I had a misfire which obviously threw a CEL and auto start wouldn’t work. Then I cleared the code and started the car up again and it ran for a few min, misfired, and just shut off. When I tried to auto start it after , no luck. Had to fix the misfire and all that for it to work again. I’m sure this isn’t going to help much, but just figured I’d throw it out there since it had to do with the auto start not working. 😅I noticed yesterday that idle was a little rough. Now under low to mid throttle, it sputters and chokes like it’s getting too much fuel. I used 91 in it, would it have anything to do with the catch can I installed or turning off the rear 02 sensors?
2012 coupe with full exhaust, CAI, Diablo tuner smaller pulley
it seems to be intermittent as well but it’s happening a lot more now. First thing I plan to check is the plugs. I am not getting any misfire codes. Also I’m running my first full tank of gas since I fixed the leak on the elbow.
