While doing some spirited driving, things went haywire all the sudden. Loss of power, check engine, loud sounds of air rushing. Found that driver's side clamp between primary and secondary cat was loose and was leaking. Tightened up, and that fixed the leak. Check engine reset itself since I started a couple times at idle.,I grabbed my hptuners, reset the fuel trims, but bank 1 still pulling a bunch of fuel. Drove down the street and Could already tell that fixing the leak didn't cure the issue. I could immediately hear the exhaust tone wasn't right and much deeper sounding not to mention the idle didn't smooth out much. So I'm pretty sure I have a clogged cat on driver's side. Waiting for pipes to cool down to get a boroscope in there. Been having to clear bank 1 cat efficiency low error recently as well.
Car has upper pulley, flex fuel(usually around 40 something percent), rotofab, and Corsa extreme axle back.
The dilemma is figuring out best option now since I need to do something about the cats with how I want the car to sound. I'm already around the max noise level I want to be at with the extremes. I figure my options are:
1. Delete cats, leave secondary cat/reaonator on, and change mufflers to the sport version.
2. Go high flow cats
3. Replace with OEM cats
3. Go nuts and do headers and change to touring version or another quieter muffler.
My least favorite option is going long tubes. Just because I'm trying to keep the mods at a minimum and keep the car very reliable and keep the whole luxury car/sports car in 1 car thing alive, plus lts are pricey. The OEM options is not appealing to me as I'd imagine they would go bad again and the tube that connects to the manifold looks kinda tiny to me. I'm leaning towards option 1 but don't know if I'd need to buy a whole new axle back as I haven't been able to find just the mufflers and am also concerned about fuel smell inside cabin when stopped. Side note, I had Corsa sport on already and after getting rear ended, they accidentally put on the extremes. Sounds great and have no problem with the mix up, but again it's at my max volume level for this particular car. If it was a Vette or something, I wouldn't care how loud.
Sorry for the rambling and thanks for any input anyone has that isn't going to do the emissions/ pollution preach
