1 - 20 of 360 Posts
For the longest time since I watched a YouTube vid of this Russian shop do a custom install in a CTS where they used the OEM screen and added a ton of functionally I really wanted that! However that didn't go anywhere.... Just before Christmas I was looking at either the Tesla screen or the Metra kit. However I was on the fence with these 2 options. I wasn't crazy about how the Metra looked in the car. The Tesla screen while it looked great and very updated had lots of issues. It really seemed to be hit and miss with it. I really wanted to upgrade the factory Nav, and I was getting really tired of the whole bluetooth audio through the Aux port. They just increased the fines for distracted driving in Ontario to obscene amounts and points to boot. I came across a vid from NavTool, it seemed too good to be true! Full CarPlay with HDMI mirroring, I watched the entire 55 min video. The really cool thing about this unit is that all the OEM stuff is still there. Ok I was sold.
IMG_1486 by Vette 71454, on Flickr
IMG_1487 by Vette 71454, on Flickr
IMG_1489 by Vette 71454, on Flickr
Below is the installation Vid from NavTool, it covers almost everything. The install is pretty straight forward, this will be one time you wish you had smaller hands. To get the factory head unit back into place with all the extra wiring was a PITA, if you can get your hands in there be prepared for lots of nicks and cuts. Everything back there is pretty sharp. I wound up using zip ties to hold the wiring up above the rear lip of the hole the HU goes into. Once you get it apart you will see what I am talking about.
I wasn't crazy about having the mic hanging off the visor, there is a small LED light in the centre of the over head console that is supposed to illuminate the shifter. Doesn't do squat, I removed it drilled out the back side just enough to fit the mic. You need to use the foam on the mic or you will get some weird noises when using it for calls. Route the wire across the headliner, down the A pillar across the front of the dash. There will be a small opening just beside the centre channel that you can fish the wire through to the HU. Your bluetooth will still work and you can use that if you want, however you need to go through the steering wheel voice button. Say hands free and then voice. If you want voice commands like "Hey Siri" you have to install the mic somewhere.
IMG_1498 by Vette 71454, on Flickr
IMG_1497 by Vette 71454, on Flickr
You must connect the yellow RCA on the main harness to the rear camera input on the Navtool unit. You won't be able to see the rear camera in the "interface mode" if you don't. However it doesn't switch to the camera automatically when in CarPlay and in reverse. It still does if you are not in the interface. This for me is just a minor annoyance and their support team is working on a fix. (Sorry don't have a pic of this)
If you get any flickering in the display when you have finished your install you need to cut the wire and isolate it in the picture below.
IMG_1478 by Vette 71454, on Flickr
The brain for the NavTool I located on the right side below the vent, see picture. Lots of space in there and secured it with some velcro. It makes it kinda easy to remove to change settings or updates.
IMG_8969 by Vette 71454, on Flickr
I used the following HDMI and USB plug and replaced the old Sig lighter adapter. This plugs into the NavTool and so far works great.
Edit this HDMI cable has Ethernet built in. Do not use. I am looking for an alternative.
IMG_1488 by Vette 71454, on Flickr
If you get stuck in this screen hold the top left corner until it exits.
IMG_8972 by Vette 71454, on Flickr
The interface doesn't turn off until the car goes to sleep, so if you turn off the car the screen will go down and it will stay on for about 15 seconds after you key off. If you exit the interface before you key off it shuts off normally.
I think thats pretty much it. Its great to have another option for our cars! Enjoy.
Edit
At the time of this post the kit was $549.00 USD - a 10% coupon code if you ask them, plus the cig adapter for $25.00
Thank you for the knowledge.
My next project Vette
Reactions: Vette71454
Looks awesome i will definitely be purchasing soon !
Discussion Starter #5
Glad I could help, had a chance to drive it this afternoon I have to say I’m really enjoying the interface.
Boom! Pop up screen with new graphics.
So if I just use the steering wheel, controls, I don't need to have the mic installed....correct? What about text to talk for the phone texting.
Thank you again! I ordered mine yesterday too this was the must needed option on the best Manual wagon on the planet
So far, any pet peeves?
Discussion Starter #8
I haven’t tried it without the mic, I am guessing it would work through the OEM mic. Next time I have it apart I’ll give it a go.
Discussion Starter #9
No not really, so far it works as advertised. All the additional functionally is awesome.
How is the sound quality?
Currently using bluetooth radio adapter looking to upgrade.
Discussion Starter #11
SQ is better then Bluetooth, and I have tried a few Bluetooth units. It’s as good as plugging directly into the Aux port. Highs and deep bass is where I noticed it most. Depending on the source on your device it could come close to CD quality. On Spotify you have the option to download very high quality tracks. Takes up a fair bit of space on your device. But that’s why I have a 128GB iPhone ;). There is no hiss or any of that nonsense you might get on the other options out there.
What a great way to refresh the oem nav system! I wish they would wire in an additional set of rca outputs so wiring in an aftermarket sub can be an option.
Discussion Starter #16
Not possible off the factory system, the amp is digital I believe. The signal is static coming off the head unit, the volume is applied at the amp. So if you take the audio directly from the HU you can’t control the volume. I have a pair of subs in mine and it works good enough off a AudioControl LC2i.
Did you look into hard wiring the power supply line instead of the cig adapter?
The cig adapter is gone, this is wired directly to the NavTool using the kit from Amazon I linked above.
Is it possible to run the cord behind the console to hide it and allow the lid to close?
Also, did you do a write up on adding your subs with the controller?
1 - 20 of 360 Posts
