1 - 5 of 5 Posts
Build list so far
Ported snout and blower by MAD
FED 311 Heads complete set
TSP She gone Cam Shaft
Manton Trunion Upgrade Kit
DMS Ice tank 7.5Gwith 3/4 kit and EMP Pump
NW 103 Throttle Body
GM Certified Reinforced Brick
C&R Heat Exchanger
DSX Aux Pump
DSX FF Sensor
Motion Raceworks Catch Can
LPE 2.55 Upper pulley w Solid Isolator
Melling HV Oil pump
C5R Timing chain
TSP Longtubes with X Pipe
ATI Balancer kit with 9.20 Pulley
DMS 4.5 intake w green filter
Injector Dynamics 1300’s
Manly rods and 9.5 diamond pistons
ARP Head Studs
Thanks for taking the time to look I’m new to the v world and have purchased all of these parts but making sure there’s not more I need before installing
Build list so far
C&R Heat Exchanger
DSX Aux Pump
DSX FF Sensor
Melling HV Oil pump
C5R Timing chain
ARP Head Studs
What block and crank?
Maybe just switch the lpe pulley to the griptech pulley and hub, they offer a lot more pulley sizes if you ever want to change out in the future. Lingenfelter I believe only has two sizes that fit their hub. Good luck with the build!
1 - 5 of 5 Posts
