1 - 13 of 13 Posts
Mont Motorsports is now an authorized wholesale dealer of Quick Time Performance Cut Outs!
QTP Low Profile kits starting at $399.99!
QTP Low-Pro Cutouts $399.99 - Mont Motorsports
^^^ LINK ABOVE ^^^
When used with QTP's wireless kit, these cutouts can be programmed to use the Homelink garage door buttons already integrated within our CTS-V's
The low profile cutout designed for vehicles with limited ground clearance.
Our oval electric cutouts feature a new low-profile design for any car or truck that has limited ground clearance. You can have the best of both worlds, they're quiet for the street, and wide open for the strip.
These electrically controlled exhaust valves bolt to standard cutouts, and can be opened and closed from inside the car with the flip of a switch. Using the convenient interior-mounted switch, you can go from stealth quiet to wide-open power. You control the volume, and you control the flow.
QTP Low-Pro Cutouts $399.99 - Mont Motorsports[/B]
^^^ LINK ABOVE ^^^
1 - 13 of 13 Posts
