1 - 5 of 5 Posts
I'm finally back to my engine build and am in the process of messaging the oil squirters to clear the JE pistons and 3.825 stroke. What is the minimum clearance I need for the oil squirters to the pistons and to the big end of the rods?
FWIW someone on another forum said .080 and right now I'm at about .030 - .040 on the big end of the rods. The squirter to piston is hard to measure so in using my precision eyeballs I would say their at least .030
Not sure about minimum clearance, but I was able to clear tweaked (bent) factory squirters on a 3.9 stroke.
Tim
Thanks for the response. Do you have any pics I could use for comparison? Also what pistons did you use?
I'm using JE pistons so the pin ribs are closer to the center.
Hood Motor vehicle Automotive tire Automotive exterior Automotive design
1 - 5 of 5 Posts
