1 - 8 of 8 Posts
Hello All,
Enjoying soaking up the wealth of knowledge on here. I'm looking at a Gen II CTS-V with the 2.3L Maggie already installed (amongst other items including cam, full exhaust, etc.). From what I've read on here thus far, if I was starting out with a stock car and has aspirations of doing the basic mods to get to the 550 - 600 rwhp range, then it wouldn't make sense to deal with the cost of the Maggie (as the stock 1.9 blower can get you there).
My question is: Since this is already on the car, is there any downside to the Maggie 2.3L setup? I'm OK with the fact that it isn't a glaring value add to have it on the car given my goals, however I want to make sure it isn't a problem.
OP, does the car your looking at have an auxiliary fuel pump or aftermarket fuel system? You will need either or to reach the numbers you seek.
Have you taken the car and put it on a dyno? Seems like that might give you a good idea of where you are and where you want to go.
I have a Maggy 2.3 on my car. (Ignore my sig, it needs updating) It does make a tad bit more power over a fully ported blower but not that much more. It also screams a lot louder than the factory blower, if that matters any. Since it's already on the car then leverage it, there are no draw backs to it.
Discussion Starter · #8 ·
Thanks all for the feedback. The particular car I was looking at was setup well with supporting mods that ended up being significantly more than I wanted to dive into (cam, cooling mods, E85, injectors, etc.). I ended up buying a 2012 sedan with 14K miles. Bone stock (for now) but am looking forward to taking this one step at a time.
1 - 8 of 8 Posts
