1 - 18 of 18 Posts
I don't know why but I can't find my last lost don't know if got deleted or not. I see the lsx376 and wondered if anyone has used this. I understand it's iron block and a bit heavier but seems like a better engine and can handle more. Opinions??
If your HP is over 700 wheel HP and you don't mind the extra weight, the iron block will be beneficial in better ring seal, more HP and less oil consumption with a higher over all power handling potential relative to the aluminum sleeved LS.
The LSX 376 is more of a “mild” boosted engine at a very affordable price. The internals aren’t something I’d imagine most would throw 1000hp at. But would be a good start with a great platform to go for more at a later date.
I would however have them opened up and inspected prior. A mate purchased a crate LSX454. Didn’t last too long before it was chewing bearing.
There are two (2) Iron Block lsX engines available.
One is the B-8, which is for low HP uses.
_Don't buy it as the bearings are absolute 'Crap'_
You are actually better off keeping your LSA Engine
if the boost is going to be ~15 psi on the _B-8.
The other engine is the _lsX Iron Block _B-15.
It is warranted for 900 HP and many are using
it up to HP levels of 1500 fwHP.
There are two (2) Iron Block lsX engine available.
if the boost is going to be ~15 psi.
The other engine is the lsX B-15.
Ahh interesting. I’ve only seen the B-8 here in Aust. They are like $7500 for a long motor.
Well, that's okay as your a multi millionaire according to what I have been told..:cool:
Thanks for the warning. I'm gonna pass on that cashew butter the wife bought this week.
Discussion Starter #10
Realistically I'm not going to go crazy with it. Since my lsa is shot I was looking at all options since I need a complete motor. I Will probably run at most 12-14psi from the lsa blower. I just didn't know if the 8 would be sufficient or go for the b15 and swap it in. Has anyone used either or? Lsa r just hard to find priced reasonable
I know of a few that run the B15 with zero issues, under 800 rwhp.
Please, do yourself a favor and make believe the B8 doesn't even exist.
I would purchase the lsX block separately, then put the correct parts in it
and the engine is good for well over the 800 hp.
If the correct parts are used, and detonation is nonexistent,
the lsX Iron Block can be used easily to 1200 hp.
However, with our little blowers and E85, I think your
800 hp is a good 'Safe' number, maybe up to 850 hp to 900 hp.
I know someone who has a warehouse full lsX iron blocks,
as well as all Dart stuff.
I think I will give him a call and see what he has to say about this.
Cheers,
Bruce
Cheers,
Bruce
I would agree with just buying an LSX block if that is the way someone is looking to go and putting the right parts in it for the expected power level rather then even thinking about a B15. Most of the time I have seen a B15 used is when someone needs an engine within a few days to drop in.
Cheers,
Bruce
I've had a lsx block on order all month seem like they are on national backorder.
Russell,
Do you want me to see if he has one on the shelf?
If so, what were you told it was going to cost you?
With or without freight please?
Cheers,
Bruce
Discussion Starter #17
More than likely I'm going to go with the lsx376b15 unless something else pops up on the meantime. Trying to stay at a budget and not wanting to wait a long time on getting something.
I'm sure you can find an lsx somewhere. A lot of shops carry them. Just build it with your own set of internals and it should coe out to similar price than buying the assembled GM shortblock.
1 - 18 of 18 Posts
