I'm getting ready to build my first LS engine and thought I'd look for any words of wisdom from the group since this forum seems to have the most experience with the LSAs. I've built several small block and big block chevys but this is my first LS. I've been reading several posts and am a little concerned about my cam choice for one and need to size the injectors. I'm thinking ID1300s for the injectors. Also I'm trying to decide between a 3" and 3.25" upper pulley for the supercharger. I'd like to be able to run on 93 pump gas but am planning on adding a flex fuel sensor to allow for E85. Also I'm hoping by going to a 3.825" stroke instead of a 4" stroke the stock piston oil squirters will work.
For starters, I looked at the Lingenfelter 900hp crank HP on 93 octane pump gas engine to get ideas and would like to get somewhere in that neighborhood. I've changed things enough that the engine will be a little unique.
-4.065 bore x 3.825 stroke (Same bore and stroke as COPO 396)
-LS9 Block and LS9 CNC Heads
-Callies Magnum 3.825 Stroke 8 CTW crank
-Callies Ultra I beam 6.125 Rods
-JE Pistons 8.9:1 with ceramic coating
-Total Seal Rings (second ring "gapless")
-BTR Stage 3 torque cam
-BTR Shaft Rockers
-Johnson 2110 Lifters
-Katech LS9 Head Studs
-Katech Timing Chain
-LS9 Head Gaskets
-Kong 2650 LSA Superchager
-ZL1 Supercharger Cover
-ATI balancer (8.66 SC Pulley)
FWIW - The rotating assembly arrived today from Callies so now I have most of the parts.
-BTR Shaft Rockers
-LS9 Head Gaskets
