Hello,
I have a 09 CTS-v that is bone stock and prior to my ownership was dealer serviced. A few weeks ago I decided I wanted to tune the car with HPT. Before I made any changes I decided to make a log of the stock file to compare later on. Its about 30 degrees here and I noticed the car was commanding 24 degrees of timing, and than timing was being pulled in and out throughout my WOT pull due to knock retard. Kind of unusual on a stock car. I got my fuel trims cleaned up nicely and removed timing (down to 18 degrees), but I kept getting random knock. Life got in the way for a week or two and I flashed the stock file back in, to continue dialing it in a at a later date.
Unrelated, I thought the idle was a little rough for a stock car so I decided... might as well pull a plug or two and take a look and see what's up. Here is what I found:
These are the stock Iridium plugs, 70,000 miles on them. Cylinders 1, 2, and 3 ironically are the worst of the plugs pictured above. It became clear the plugs needed to be changed. What's surprising to me is how inconsistent every cylinder was. Cylinder 7 was the best of all the plugs. You could clearly see the iridium tip, while again the worst plug had no tip, and a gap of almost .10 .
I replaced the plugs with BR7EF plugs gapped at .033 . To my disappointment, the low idle misfire is more pronounced. I have not had an opportunity to do any pulls with it to log data, but hopefully will do so tomorrow.
Thoughts on what might be going on here? I would like to get it running well before I modify it.
Dan
Dan
