Logging a wideband?
722 Views 7 Replies 4 Participants Last post by  Pavetim
I was going to pick up a MPVI3 and was wondering do any of you guys know can you pin a wide band I to the ecu so the can bus reads it through the ond port or do you need the pro link cable?
1 - 8 of 8 Posts
The AEM 30-0334 gauge can do this. Comes with everything needed and is a simple installation.
I actually happen to have a brand new AEM 30-0310. Does this work also? I have no problem running it to a prolink cable but if I can get the data off the obd port from the ecu I don't have to run wires through the windows and shit when I am logging. The one you stated looks lile.ypu need to use the garage, I have nowhere to put a guage
2
No, you need OBD2 pass through connector to be able to pull it up on HPtuners easily with no wiring into anything - Amazon.com
Cable Font Electrical wiring Audio equipment Wire
Price of the cable I will probably just but a 0334. I just wonder if garage has to be hooked up to work or if I can use without gauge
the gauge is the controller for it so u can also set it up as well as being needed for the operation, u can hide the gauge somewhere its small so easy to fit if u dont want to see it
like he said, you can hide the gauge and just run the obd2 cable so the data can be pulled up in hptuners to datalo AFR
Ok cool thanks for the info
1 - 8 of 8 Posts
